Originally Posted by SirTanon
Originally Posted by Propflux01
Just remember to read on alittle further in that manual, which usually states to "from then on, change every two years or 30,000 miles". Funny how it can go from lasting 5/150k to 2/30k and the fluid is identical.
I'm pretty sure this is based upon the assumption that people will put the wrong stuff in. When mixing "universal coolant" (Read as "incompatible chemistries"), it's generally accepted that, even if both on their own are "long-life" or "super long-life", the resultant mixture is only really good for (at most) 2 years/30,000 miles.
SirTanon you are correct.
Out of my 2002 2500HD Manual.
Engine Coolant The cooling system in your vehicle is filled with DEX-COOL engine coolant. This coolant is designed to remain in your vehicle for 5 years or 150,000 miles (240 000 km), whichever occurs first, if you add only DEX-COOL extended life coolant.
The following explains your cooling system and how to add coolant when it is low. If you have a problem with engine overheating, see "Engine Overheating" in the Index.
A 50/50 mixture of clean, drinkable water and DEX-COOL coolant will: Give freezing protection down to -34F (-37C). Give boiling protection up to 265F (129C).
Protect against rust and corrosion.
Help keep the proper engine temperature.
Let the warning lights and gages work as they should.
NOTICE:
When adding coolant, it is important that you use only DEX-COOL (silicate-free) coolant. If coolant other than DEX-COOL is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will require change sooner -- at 30,000 miles (50 000 km) or 24 months, whichever occurs first. Damage caused by the use of coolant other than DEX-COOL is not covered by your new vehicle warranty
From my 2000 WS6 Manual
The following explains your cooling system and how to add coolant when it is low. If you have a problem with engine overheating or if you need to add coolant to your radiator, see "Engine Overheating" in the Index.
Apparently at this point in time GM didn't realize that DEX-COOL would be a problem or they figured people who actually knew something about cars were buying WS6's and didn't need the warning...
