Yet another post from me on my LIM gasket replacement job! Two questions in this post:
I picked up the new gaskets today and was looking at them side by side with the new ones to try and find the fatal flaw in the originals. My interest in this is both based on simple curiosity, and the fact that if the original gaskets *don't* have a leak, I'm on a long and somewhat painful wild goose chase.
I can spot an obvious flaw in the gaskets I removed, but it's hard for me to be sure this hole (on the right side of the rectangular coolant port) isn't damage from me tweaking the manifold around while removing it:
Does this look like a typical sign of failure? If not, what should I be looking for?
Second question: I was very pleased to learn that the FelPro gasket set comes with rubber strips to use to seal the front and rear where the intake seals against the block. But when I was in line to buy the gasket, the guy behind me apparently noticed what I was buying and told me not to use the rubber pieces, instead to use silicone liquid gasket. I very much appreciate all the help and first hand advice I've gotten on BITOG lately, and my question here is in your experience are these rubber pieces worthless? Seems like they'd be easier to install given they won't really smear around...
