Originally Posted By: SteveSRT8
Absolutely not true.
More speeds allows for a wider spread of ratios, increases performance while simultaneously allowing better fuel economy. ESPECIALLY important to smaller motors, or any motor with a peaky power curve. These will have real world torque capacity, something a CVT simply cannot presently give us.
ZF 8 speeds are in Audis, BMW's, Bentleys, etc., and they are extremely durable and efficient.
Wrong, Steve. More speeds makes for narrower speed ratios; not wider. Not that this is a bad thing....adding more speeds between gear 1 and gear 10 makes for smoother transitions, a better nicer driving experience (and quieter too).
You're also wrong about CVT not being able to "hold torque". The limitation here is not hardware, but software. With the correct chip programming, a CVT can handle torque even better then a conventional tranny because a CVT has more ratios for the programming to dial in.
