I changed the oil, coolant, and differential oil on my father's '97 Safari recently, and I noticed a pattern. As with my old Grand Am and my mother's Sunfire, there is no drain valve on the radiator, so I had to pull a hose and try to catch as much fluid as I could in the pan. I figure I caught about 6 liters and dumped 1 on the floor. To change the differential oil, I had to remove the cover, as there is also no drain plug on that. I noticed there is no drain on the transmission either, as it is with the Sunfire and was with the Grand Am. The lack of these drain plugs makes routine maintenance a lot more hassle than I think it should be.
Is this aversion to drain plugs mainly a GM thing, or have I just been lucky on the few other vehicles I've worked on? My Mazda3 has a radiator drain valve, like my old Pathfinder and the ex's MX-6. The MX-6 has a drain plug on the transmission (auto), and the Pathfinder has a drain plug on the differential. The Mazda3 and Pathfinder have drain plugs on the manual transmissions, of course.
Now for the comedic relief:
The coolant was the sludgiest coolant I've ever seen, yet he seemed annoyed with me when he found out I didn't save the coolant for him. He doesn't believe coolant goes bad, so he would have just used it again after letting the solid matter settle out. I refilled with the Prestone AM/AM he provided.
