I think in many cases = ProfitsSad!
First Toyota now GM! What's going on with the engineering and/or manufacturing of new engines?
Sad!
Incoming QC sampling plan should catch that. I don't know but guessing ISO/TS IATF 16948 + 9001 QMS is pretty robust.I've read its surface finish issue. How does that happen? Certain batch wasn't made properly?
Not to belabor the point, but it was probably Hyundai/Kia that buggered up the engine manufacturing process first with their Theta engine.Sad!
For people that don’t know how serious this is, I found this 60 Minutes piece very eye opening. I had my airbag replaced, but I live in Georgia where it’s humid most of the year. Am I still driving a ticking time bomb?Let’s be fair here, not just GM.
19 automobile makers, 34 brands
67 million airbags
And Honda brand was the most serious issue of all of them, the models below are labeled do not drive and they are not General Motors cars.
“Models flagged as being at an extreme risk are certain 2001 to 2003 Honda and Acura models containing so-called “alpha” airbags, and the 2006 Ford Ranger and Mazda B-Series pickup trucks. Also included are the 1999 BMW 323i and 328i.” NHTSA advises that owners not drive these vehicles and seek immediate repairs.
https://www.consumerreports.org/car...call-everything-you-need-to-know-a1060713669/
The new engines are only certified for 0-20.I sped it up until i saw a document and it's near the end. It has all the things listed for an engine replacement and a switch back to 0w-20 again.
Connecting rod bearings.What bearings would those be?
Bearing shells aren't hardened, they are intentionally made of soft material to protect the hard material of the journal and to allow abrasive material to embed in them so that they don't score the heck out of the crankshaft.Connecting rod bearings.
Correct and if a new engine is not put in the vehicle 0w40 is the new oil recommendation.The new engines are only certified for 0-20.
Well what caused them to heat up so much that they fail?Bearing shells aren't hardened, their intentionally made of soft material to protect the hard material of the journal and to allow abrasive material to embed in them so that they don't score the heck out of the crankshaft.
Typically what causes a bearing to fail is inadequate MOFT, allowing the journal to touch the bearing, and if this exceeds the capability of the AW additives (which can tolerate this happening momentarily), the soft babbitt welds itself to the journal, which causes the bearing to spin. This then often results in the connecting rod seizing, so the whole piston/rod assembly stops rotating around the journal, resulting in it being forced into the side of the cylinder, breaking the wrist pin off the piston and shoving itself through the side of the block, windowing it.Well what caused them to heat up so much that they fail?
MOFT was too small with 0w20.Well what caused them to heat up so much that they fail?
I belive in to big tolerances and bad finish and there a thicker oil will make it last longer but not so long that a well built engine with the right tolerances would be holding up. The 0w40 may just be a way to give GM a little longer time to built enough engines for replace the bad onesMOFT was too small with 0w20.
*clearances.I belive in to big tolerances and bad finish and there a thicker oil will make it last longer but not so long that a well built engine with the right tolerances would be holding up. The 0w40 may just be a way to give GM a little longer time to built enough engines for replace the bad ones
Tnx for correcting my bad English*clearances.
No problemTnx for correcting my bad English![]()
It's not like they were blowing up immediately on 0w20. Normally antiwear additives would pick up where viscosity can't quite handle periodic high load/dilution but if it's working as designed there isn't any metal to metal contact.I belive in to big tolerances and bad finish and there a thicker oil will make it last longer but not so long that a well built engine with the right tolerances would be holding up. The 0w40 may just be a way to give GM a little longer time to built enough engines for replace the bad ones
