gm 6.2l cylinder 8 misfiring only at idle
Fort Worth, Texas
Yes, there is vacuum leak at valve covers, I’m planning to change the gasket for it, not sure how valve cover vacuum leak can make that difference. Please advice
The only vacuum leaks the valve covers will cause is PCV related which will lean all 8 cylinders....Not just one.
RI
have you done a dynamic compression test? Your best bet is to apply compressed air into the cylinder with both valves closed and see if you have any leakage.
But my question is, if there is misfire because of compression issue then why it’s acting on cold start or idle speed.
RI
Static compression can be normal but you can still have a dynamic issue. Idle misfire is likely from a valve train problem, whether a valve not fully opening (cam problem), excessive carbon buildup, etc.
That is why I asked you if you actually measured the rocker arm travel instead of just watching it.
Thanks bud, I’m not that much technical to measure all this, I’ll take it to my mechanic and let him do it for me. Thanks
Texas
mattd has a valid point. I remember when the Chevy 305 V/8s had a widespread problem with cams going flat (yes, I'm old). One of the first signs of this problem was an idle miss.
