2002 Malibu 3.1L, about 80 k miles. It had the intake gaskets done about 2 years ago by a mechanic and I think they put in their bulk green antifreeze. Before that it had peak global lifetime after the dexcool factory fill.
I want to change the 12 year old radiator hoses. Are there any other pressurized rubber coolant hoses I should change at the same time to prevent getting stranded? Ill try to replace the hoses myself if it seems easy enough. If not ill take it back to above mechanic and have him do it along with the serpentine belt. Plugs should be good for a little while longer I think, or not cause me to be stranded.
Once I change the rubber, Ill have to flush/refill. Would like to use toyota red to stock only one type of coolant. It would be nice to keep them all the same just for ease of changes later, but it's not mandatory. I could go back to Peak global lifetime, or what else? Hopefully the IMG will be good for life.
