Pliobond 20, or whatever equivalent compliant version is available in your state. Some formulas can't be sold in MA for example, due to VOC's.lots of plio bonds which one!!
Yes, the car is at church so I can't take a picture right now. BUT, you are correct in the location. It's that little 8 inch by 4 inch paddingIf I understand you correctly, the dash panel trim is lifting from the knee bolster area?
This is a pretty standard adhesive for automotive trim like that - headliners, etc. Would likely be what I would reach for first, 3M Super 77:
https://www.acehardware.com/departm...cY-Yrx8dtpV2O3yzF-xoCKnoQAvD_BwE&gclsrc=aw.ds
The presumption with this stuff is you are doing a larger area thus the desire to spray an even application widely. If it is a small area, I see no reason contact cement as mentioned above by supton would not work just fine.
Gebo, good to see you back here. Please let us know what you wind up using, and how well it works.Yes, the car is at church so I can't take a picture right now. BUT, you are correct in the location. It's that little 8 inch by 4 inch padding
that comes from the ignition switch down to your right knee.
