I have an '03 Mitsu Montero.
quote:
Let's clarify that Manual Transmission Fluids (MT's) and Differential lubes are two entirely different lubricants and their formulations reflect that fact.
GL4 is sometimes specified for components such as TC's and MT's because many mechanical engineers lack any knowledge about gear lube formulations. GL4 refers to the level of EP protection provided by the lubricant.
These two statements confused me for a while, but I think I get it now.
The problem is that when I go to Kragen, they have a bunch of "gear oils". Valvoline, Mobil 1, etc. They are all labled as "gear oils" and they all say Gl-5. They do not have some gear oils for MT's and TC's and other gear oils for differentials. So you are essentially saying that you would never use one of these dino gear oils in your transmission because they would not work very well. Right? They would not hurt any thing, they just would not work too well.
Then you go to some high end oil brands like Redline and they market specific gear oils for Manual transmissions and other gear oils for differentials. (All good stuff no doubt).
So, you are saying that you should use gear oil specifically formulated for MT's and another type of oil specifically formulated for Diffy's. It is just that the GL4 GL5 has nothing to do with it.
As you can see from the links, I have question this before. I guess I am just a slow learner regarding this issue. I think Ive got it no.
I think I have just made the water more muddy.
[ March 09, 2006, 04:43 PM: Message edited by: Winston ]
