Overuse of fuel system cleaner can cause higher iron (and perhaps other metals) if I'm not mistaken. Hopefully TeeDub will check in on this thread again, notice you said that and provide more comments. I believe the dosage for redline's fuel system cleaner is not to use the whole bottle in one tank.
Anyhow, I noticed higher iron when I used the Redline fuel additive in my BMW. By the way, as Shanneba said, the BMW 5w-30 Synthetic is a good oil, so is GC. Both are heavy 30 wts, almost exactly the same viscosity at 100c.
Also if I'm not mistaken, the upper engine metals TeeDub is talking about are tin and chromium as TR3-2001 pointed out.
As you are a newer member, I thought it would be helpful for me to point out that there are several people with a great deal of knowledge to add, and you are lucky when they pipe-up with respect to your oil analysis. TeeDub and Ekpolk are among those, so you are lucky to have their advice. In my own case, from what I have observed on this site, my own approach if I were in your shoes would be to take that advice.
Good luck to you and welcome to Bitog!
