That procedure is pretty consistant with the procedure in the Haynes manual. I tried it. It works. That's the good news. The bad news is the blinking sequence, a 24, is not on the list of codes and diagnostics. I'm also thinking, unless something seriously changes, its going to be a problem I can live with, as driveability is fine, mileage is where it should be. I will defer it until the next major instance of where I have to take it into a shop. Same with the catalytic converter, and probably stick with something more OEM, rather than generic, if that poses a problem in passing my next smog. Thanks for all youse help.
