Yeah, I agree, though by us there will always be a gas station. I am now thinking that even with only a 120 (96 actual) gallon propane tank it might be viable for short term blackouts of 24 ish hours if using a fuel efficient inverter. We have propane cooktop, water heater and fireplace. Having a connection for an inverter would be simple. More so with a unit that is just enough lets say to power the refrigerator, a cheap window AC unit that can be stored in the garage with the inverter and the TV as well as a few lights.I am not a fan of gas only generators for areas where there might be damage from a hurricane requiring a generator. Storing a lot of gasoline before a hurricane is a PIA and dangerous. If no damage then need to use it in your car. Finding open gas stations with gas after a powerful storm can be difficult.
Propane is a better fuel for a generator bought to use during a storm. Even if you have to buy a tank for propane. It does not go bad.
Anyway, the key is, from what I understand with my limited knowledge even a 96 gallon referred to as a 120 gallon (420 lbs) propane tank is not enough, more so is it isnt always full since it is in constant use. I doubt gas grill 4.5 gallons (20LB) tanks will last more than a few hours, you would need a lot of them its only 4.5 gallons. Propane is j ust not practical if you dont already have a large propane tank should you want to be prepared for the BIG storm. Keeping in mind my comments are based on losing long term power every 10 or more years.
Though, having the option for both would be nice. I could run off the 120 gallon propane and if it gets low switch to gasoline.
Im liking the idea of the mentioned 7000 watt mentioned above, maybe I could get by on less even, since I dont anticipate many uses for it though 7000 would be ideal.
https://www.amerigas.com/about-propane/propane-tank-sizes
