Given: Engine oils wax and thicken over time. What happens to gear oil over time? In my motorhome with a Dana S110, I will never hit the recommended 100k service interval. Jeep also states the gear oil in their manual transmission is good for the life of the vehicle. (seriously)
I have two questions:
Time:
How long can gear oil go between service via time, not miles?
Limited Slip Additives:
Every retail 75w90 out there I have found from Mobil 1, Valvoline, Lucas all contain this additive. Yet, none of my differentials require it the Dana 44 and S110 nor my 2500 GM; no clutches in any of them.
Does the additive in a heavy duty axle, the s110 or the 2500, suffer from this additive? Is the extra expense worth it for gear oil without any limited slip additive? In fact, Dana told me they will add a year to the warranty on their hd axles if you use their FE75w90 with no ls additive. The cost of Delvac 75w90 with no limited slip additive roughly doubles from Mobil 1 75w90. Is it worth it?
Thanks!
~David
Time:
Thanks!
~David
