gear oil for kodiak 450
On. Can.
Will 75w 89-90 marine gear oil be okay
for a 2018 450 Yamaha Kodiak atv?
Have 3 quarts at home.
Front and rear diff.
Thank you very much.
p.s. My first atv.
Gouda
You should take some time to read the owner's manual. According to what I see, the rear brake on the bike is a wet brake which typically requires special oil and not a "standard" gear oil. I used Shell Spirax S4 TXM in my 2010 Kawasaki Brute Force 750 with great results. I would assume something similar would work in yours provided it meets the specification.
However, if you have a warranty, I would simply buy the Yamaha oil and not risk it (at least until the warranty expires).
p.s. My first atv.
Gouda
I was a moderator on this site many years ago but it looks like things are real quiet over there now?
http://mudhole.ca/index.php?sid=601db6219a2e95cab6aa8c40448e031a
Regardless, there still might be some good info you can get from the site? (Yamaha section or Tech tips)
And also, even though this one looks quiet, I am sure there are others around if you Google them or just Google what you're looking for, and I am sure something will come up.
I had an 05 Grizzly and my Father an 05 Kodiak and used Amsoil Severe Gear in mine but maybe things have changed considerably since then as far as fluids go?
