Originally Posted By: maineSS
I looked at the ASTM D-130 part of the "Automotive Gear Lube Study" (Copper Corrosion Test), and see that NONE of the tested oils pass the 1a classification- which is what I'd want. Also, there's no mention of the type or percentage of EP additives each oil has, which makes the corrosion data difficult to evaluate. I'm assuming these are GL-5 oils- as the classification isn't mentioned, either? Otherwise, it's a good writeup of testing methodology.
What's wrong with a 1b pass ?
Most all dual rated GL4/5 manual trans/transaxle fluids have a 1b copper corrosion test pass and are fine for use in sycnhro 'boxes with bronze synchros.
I've never had problem with them, one gearbox I have has over 400,000km on it using these fluids and still shifts flawlessly.
