Gear oil break-in change intervals?
I follow Lake Speed closely, and I'm well aware of the engine break-in protocol, which I do. I was wondering if there was a guideline on break-in fluid changes for diffs as well? I did my first one at 899 miles
I'd ask the manufacturer of the ring and pinion gears and/or posit unit. Most cars and truck run on the factory fill for the life of the vehicle without a change at all.. I don't recommend that, just pointing out that set up properly most gear sets are pretty tough.
  • Like
Reactions: RBT
For aftermarket gear sets, this is typically recommended (see page 5):
https://www.richmondgear.com/wp-content/uploads/pdfs/richmond/cat-32.pdf
I have done rack and pinion sets from Richmond, Yukon and Motive and pretty much followed this procedure and been fine.
For brand new cars / trucks, the few that I have owned, I just follow the owner's manual which is generally no towing for the first x (500, 800 etc.) miles.
I mostly do 25k on a new vehicle and within a few thousand miles if a used car. After that, I generally run 75k for both front & rear. Subaru front diff is brutal on even Amsoil, Valv synthetic. Exception being BMW's in my sig. I simply do diffs, transmission fl, and X-Drive locker every 50k. Amazing to me how small even the X3 lockers are.
https://www.thedifferentialfluid.co...rential Oil Change After Initial Break-in.pdf
etc.
I think the rule of thumb is to replace the fluid at 5K, after most of the break-in has occurred.
The thought of running the fluid further with all those contaminants is nasty. I've seen what lubricant contaminated with break-in debris does to bearings, and it's not good. I tried to talk to manufacturers, for them to go away from the "filled for life" trend that is pervasive in the automobile industry, and specify a fluid change to get rid of break-in debris that would go a long way with improving reliability of their product. Unfortunately, their customers are enamored with the "filled for life" feature presented to them. And the manufacturers are chiefly worry about the warranty period.
