Gear lube in engine oil
Ontario
I have a 75hp Mercury 4 stoke. I changed the oil and filter and added 5 litres of new oil. I needed a little more to top it off but unfortunately I grabbed my gear lube. I quickly caught myself but probably added 50ml of gear oil to the engine oil. Question, am I ok to run the engine with this little bit of gear oil or do I need to drain and add new oil? Thanks
That is under 2 ounces , that isn't much.
My only experience with this was years ago at a car dealer, the bulk oil tank for 30 w got filled with 90 gear.
Several vehicles came back with damaged engines .
5 Liters = 5,000 mL oil and 50 mL gear oil.
So you added slightly less than 1% gear oil (please check my math).
I would not worry about it in my boat and I have Mercs.
10w30 or 25w40 ?
Follow-up.
Now you have me wondering what the effect will actually be.
Is it the Mercury High Performance Gear Lube SAE-90 or the Premium 80W90 ? I am assuming you use premium for outboards?
For some reason these two are not be mixed:
https://www.mercurymarine.com/en/us/part...ants/gear-lube/
I don't think 1% is enough to matter but lets see what a tribologist says.
Edit:
I am running by West Marine shortly and I will ask them why the two lubes can't be mixed. That might provide some insight as to they will countersct with motor oil.
Gear lube has sulfur in it which will attack your engine internals. How much, IDK, but it's not good.
Originally Posted By: MolaKule
I would change it before winter storage.
Good to know but the OP lives in FL, his winter may not be the winter you think.
I don't think it'll hurt anything. I have known many people who have added an entire quart to their car engines in the past.
Maybe run the OCI a little shorter than usual.
Ontario is in Canada.
What the heck, I could have sworn it said Orlando.
Guess its time to get a stronger eyeglass prescription.
Gear lube and yellow metals may not be compatible (depends on the lube)... 25W-40 is stout oil and the add pak will likely absorb the gear oil OK. I would not be concerned as this is tiny dose.
But I'd try real hard not to do it again
