Yes I'm revisiting a topic several threads have touched on. I've seen a number of threads dealing with these two popular weights and why each is used and have watched them with interest.
First let's remove ambient temperature from the discussion and presume a fairly moderate nominal year round temp to simplify the discussion as a focus of the axle itself.
Here are some points I've seen entioned here as technical reasons for why a ...140 is selected or a ...90 is selected (in no particular order - these are not MY reasons - just a collection):
1) Shock loading (heavy pulling, hot rodding, etc...)
2) Size of ring gear
greater_than 9" == ...140
less_than_or_equal 9" == ...90
3) 'Built'* for ...90 or ...140
4) Sound quieting w/ ...140
5) Tolerances in axle design
6) Other...?
I figure it is some weighted combination of these but am yet to see what I would consider a conclusive and definitive rationale for a ...90 or a ...140 to be used in a given axle.
*Built... I mention this because while this doesn't really tell us anything - it gets mentioned a lot and it begs the question 'how' is an axle 'built' so as to require one or the other. For that matter, do engineers pre-select the weight of lubricant and then engineer their axle design around it as a design constraint? Or do they determine a weight of oil after the fact that best works with the axle as designed? What comes first, the chicken or the egg?
6) Other...?
