GDI sonata pinging.
Texas Hill Country
I take very very good care of my cars, and if anything is even slightly wrong, I fix it. Have a 11 Sonata 2.4L GDI, absolutely love the car. Drives perfect, 40k miles. Pearl white, spotless from Northern Texas. Bought the car, smelled the oil it smelled like fuel. Figured it was due to short trips by the dealer. I have been changing the oil out every 3k miles using Chevron Supreme 5w30 and Hyundai OEM filters. After the 3rd oil change, judging by smell alone, I have the fuel dillusion issue under control. It drives me nuts that after 1500 miles the oil gets jet black. I suppose this is a known issue with these direct injection engines. So, the car burns about 1/2 quart of oil in 3000 miles. I top it off. I am trying to get it to burn no oil, so I switched to a lower NOACK motor oil. I chose Valvoline Maxlife Blend 5w30. My next oil change will be Maxlife Full Synthetic 10w30 which has a NOACK value in the 6's. 5w20, 5w30, and 10w30 are all approved in this engine per the book. I will be running the 10w30 in the Texas heat, which gets up into the low 100's. Now I am reading some articles on low speed pinging in some of the new turbo GDI engines. This is remedied by the OEMs with full synthetic motor oil high in Calcium. What does the lube have to do with pinging? I thought that was fuel related, or carbon buildup related. Anyways, on 87 octane, top tier, this thing pings like crazy mostly at low speed. On 89 octane, it still pings. Does not ping at all on Costco Top Tier 93. Did not expect to have to feed a hyundai sedan premium, but I have been doing it. I'm glad that fuel in Texas is cheap in comparison to many areas, I am paying $2.19 right now for 93. I have been using chevron techron every 3k miles. I would like to get the pinging issue on this car resolved, it should run on 87 just fine. I have no desire to go into the engine and scrape the carbon off the valves, nor should I think that a 40k engine should have carbon on it. I am considering taking apart the intake hose, and spraying some GDI cleaner in, right before I change the oil next time. The other thing I am thinking about is plugs. I have read that these plugs get trashed in the GDI engines. The turbo engine has a 30k interval for plugs, the non turbo is 100k. The plugs are $10 each for OEM denso plugs. Do you all think that plugs would have anything to do with pinging? I reluctantly paid the dealer to do a steering coupler in this car a few weeks ago, I asked if there was any new engine calibrations for this computer, they blew me off and said no nothing.
Phoenix
Some of these engines had issues with metal shaving left in the engine during manufacturing. Oil loss between oil changes is a symptom. You might want to check to see if your engine might have this issue. Hyundai is offering free engine replacement on affected engines.
Sunny Florida
You are correct that the plugs can experience accelerated wear, but some pinging can be called normal or acceptable. I would also make sure and get some of the LSPI oils we discuss here ad infinitum. GDI has part throttle distribution issues, especially in early versions for many mfgrs. This is why we see the combination port/DI setups coming out now.
JustinH
Texas Hill Country
Engine was tested by Hyundai by previous owner. Their TSB is to install a different dipstick which raises the engine oil full level from 4.8 quarts to 5.2 quarts. I have the new dipstick, engine gets 5.2 quarts of oil. Hyundai considers half quart in 3k miles to be normal, and so would I. I have the warranty extension paperwork, they guarantee this engine to 120k miles. They only replace the engine if it is banging, has spun bearings. Mine runs fine and sounds good.
JustinH
Texas Hill Country
I was under the impression that detonation would spell death for an engine, so certain levels of it are acceptable? Constant detonation at low speeds drives me absolutely insane on the 87 octane. I'm glad I have the issue "resolved" with high octane fuel.
Nick1994
$100 site donor 2023
Phoenix, AZ
Log into the Hyundai owner's site, I'll post the link below. I did and put in my VIN and it came up that a software update was ready for it. I read in the Hyundai forums that it really makes the car more responsive and boy did it, although it's not supposed to change how the car drives. Not sure what the update was for, but you can check Hyundai's website. https://www.hyundaiusa.com/myhyundai
JustinH
Texas Hill Country
I think it is a not bad car, but the service manual is not appropriate at all. Hyundai should have spec'ed a higher grade motor oil, a 3750 interval mandatory not just severe, and changed the octane requirements. I had the displeasure of driving one of my wife's friends Kia Optima's the other day. Similar year. Car runs absolutely terrible, burns oil like crazy and pings all over the place. Has very little power and stumbles all over itself. My wife drove it, and when SHE comments that it runs much worse than my Sonata, there is something seriously wrong. Wife's friend has Kia dealer service car per standard service interval.
Tucson
According to this (found on another thread here): article you want less calcium in the oil, not more. The idea that a slightly higher oil level would cure pre-ignition sounds like nonsense to me. But one oil-related cause could be that oil is being sucked in through the PCV system (very common). Going to colder plugs can help, but is not a real fix. You should check for vacuum leaks, for example from manifold bolts that aren't properly torqued.
east tn
My 2011 2.0t se doesnt ping but you can tell it doesnt pull as hard with 87etoh vs 93 all gas. I change pretty much as you do but a grade heavier. The warranty only gives you a fresh short block. I like the car, i hate the company. Its at 69kmiles. I changed the plugs to evo x 1 grade cooler and have a catch can . I use synthetic group 4/5 and a little of the advertising "synthetics".
OH
This morning I saw some Gumout Octane Booster on clearance for $2.84, only two left. I'd try some of that.
TX
Haven't had any pinging in 120k miles. I've always used regular fuel. Plugs came out looking great at 95k. The engine is noticeably more noisy than others due to the high pressure fuel pump that sits on the rocker cover.
OH
Sorry, meant to say this was at Walmart.
TX
Wrong. Short block warranty was extended to 120k. You don't get a replacement unless your engine grenades. Proof of maintenance must be shown.
E. Tennessee
Originally Posted By: double vanos
Castrol Edge 0w40 and premium fuel. Still a high calcium oil but should mitigate your consumption issues. Premium fuel helps with LSPI. I know, I'm a broken record.....
I'd also suggest a good OCC on the PCV side as well. I run the Saikou Michi custom cans (excellent parts). I've never had pinging. I do run HKS M40XL plugs now that I have a good ECU tune as well. This is a colder plug than OEM and along with all the other modifications seems to abate the nasty "ping monster" while creating a large increase in usable HP/TQ and for me about 2MPG better gas mileage.
