GC now in our 2001 Impala.
Pittsburgh,PA U.S.A.
The last two OC I ran M1 Drive Clean 5W - 30. The first for 3K and the second for 4K. The second was the first time EVER I ran an oil for more than 3K.
The 2001 Impala with the 3.4 (intake gasket done twice, second time with most recent) now has 62K miles.
This time I went with GC and an extra long P1 filter.
The plan is to run this OC for 8K, then change again with GC and a new P1 extended filter, and when second run of GC gets to 8K to leave it in but send a sample out for analysis. Might push it to 10K or even 12 K depending on what comes back.
So what do you think of this plan?
I've got a 2003 Impala with the 3.4 and about 72,000 miles, and so far no intake gasket problems (keeping my fingers crossed). Engine seems to run very clean. Last OCI was about 4200 on PP 5w30 and a PL10111 with no oil consumption and oil looked very clean when it came out. Just judging from what it looked and felt like I would guess I could have gone 6000 easy. This car seems to be easy on oil. My wife mainly uses the car for short trips and lots of starts and stops, so I would consider it severe service.
Which longer PureOne filter are you using now?
Doesn't you '01 Impala have an OLM calibrated for SL dino, and if your IMG isn't leaking why not use the OLM as a reference?
The OLM for the 2001 Impala just gives a service message on the dash display. It does not give percent left, and frankly I think it is based on about 3K OCI.
Maybe later models have a better OLM but as for the 2001 Impala I was never very impressed by the OLM message coming on at less than 3 K when I knew I had a good oil that still had plenty of life left on it at less than 3K miles. And by the way, the oil also was not low.
Jim: The OLM in our 2003 is no better. It just pops on and says something like "Change oil."
What PureOne number is the longer filter you are using?
BTW I think one of the most important things to running any oil for more than 3K is to properly maintain the vehicles cooling system. If the engine runs too hot because the cooling system can't keep up, then the oil probably will break down early, might not even make it to 3K.
I spend money on vehicle preventative maintenance , not on AAA membership. I have the cooling system in our vehicle flushed every 3 years, and replace belts, hoses, and batteries when they are worn or too old. Also change transmission fluid and filter (including torque converter fluid) replace fuel filter, air filter, belt tensioner, and have starter and alternator rebuilt before they go bad.
Also have a set of Blizzaks on rims for winter for both vehicles.
You're right some (and also later) models had an actual percentage left readout. However your model is not simply a mileage based counter set for 3k. It factors in tons of real time data to give an accurate oil change time. The actual mileage WILL vary with a multitude of conditions.
One thing you left out for longer than 3k oil changes is to properly maintain the PCV system. If it's not working up to par, then you can get a sludged up engine.
