First column is current, second column is M1 5W30 w/5,774 miles on the oil.
Equipment make: Subaru
Equipment model: 2.5L Turbo
Oil use interval: 5,930 miles
Oil type & Grade: Castrol Syntec 0W30
Make-up oil added: 0
Miles on unit: 21,930
Air filter: Amsoil
Oil filter: OEM
Aluminum 4 6
Chromium 1 1
Iron 10 15
Copper 6 20
Lead 2 2
Tin 0 0
Molybdenum 12 63
Nickel 1 0
Maganese 0 0
Silver 0 0
Titanium 0 0
Potassium 0 3
Boron 14 115
Silicon 15 18
Sodium 2 6
Calcium 2582 3394
Magnesium 106 10
Phosphorous 680 764
Zinc 818 904
Barium 0 1
Properties
SUS Viscosity @ 210F: 64.8
Flashpoint: 365F [>385]
Fuel %: 1.0 [ Antifreeze: 0 [0]
Water: 0 [ Insolubules: .4 [
Dennis: Nice improvement. You can see your engine maturing in wear with this sample. Most metals have settled down, though iron and copper are still a little above average. They should drop more in the next sample. We did find a little bit of fuel dilution, which is common in engines that see a lot of city driving and/or idling. We don’t consider it a problem until it reads above 2.0%. No other contaminants present, and the viscosity was normal. The fuel isn’t hurting anything. Looks great!
This was my first GC UOA. I'll be switching to an OEM air filter soon. I think I might not be getting seal with the Amsoil [plus it's noisier now that I have an aluminum skidplate].
I'm guessing that fuel dilution is due to the fact that it was winter and I drive five miles each way weekdays. I probably didn't "push it" as often as I would've liked [no track, strip or auto-x]. It looks like the additives and viscosity held up "ok" despite the dilution, right? No make-up oil added, although it was about 1/2 quart low right before I sampled it.
Haven't decided on what to use next [GC, M1 10W30 or 0W40]. May push it a little harder during the summer and will do some light off-roading [beach, etc]. Also drive to SC during July.
Comments/advice welcome.
-Dennis
Air filter: Amsoil
Oil filter: OEM
Aluminum 4 6
Chromium 1 1
Iron 10 15
Copper 6 20
Lead 2 2
Tin 0 0
Molybdenum 12 63
Nickel 1 0
Maganese 0 0
Silver 0 0
Titanium 0 0
Potassium 0 3
Boron 14 115
Silicon 15 18
Sodium 2 6
Calcium 2582 3394
Magnesium 106 10
Phosphorous 680 764
Zinc 818 904
Barium 0 1
Properties
-Dennis
