Canadian gas still has MMT in it, so that's where the manganese comes from. I wonder if manganese hurts or helps the wear numbers? Does it hinder or help the chances of doing long drain intervals?
The oxidation, nitration and sulfation numbers are always high from the lab I use and I don't believe them to ever be accurate, especially after I sent an early 740 mile sample of Schaeffer Oil last year and it showed 40% oxidation on it, which I seriously doubt was the case. As I mentioned higher up in this thread, Terry even told me he thinks the numbers in these three tests could be 2-3 times higher than they really are. If you look at the condition of the rest of the numbers, it can't be true that these three numbers would be so high.
[ October 17, 2003, 04:54 AM: Message edited by: Patman ]
