The Gatorback serpentine belts are very good buy. The crosscuts makes the belt more flexible, better grip, and resistant to cracking that the solid serpentine belts run into.
Since you are changing your belt(s), check over your belt tensioner and pulleys. The belt tensioner takes the abuse of being under constant pressure and exposure to the elements. The bearings of pulleys eventually wear out, making the pulley loose or causing the pulley to lock up.
