Not sure about that. Honda dealers list Mitsoboshi belts in their catalogs as the current oe replacement belt. You did say the replacement mitsoboshi is not as well made as the original mitsoboshi and you offer up the unita as the answer.. Cornfused
That is not correct. Honda specs part# 14400-RCA-A01 for almost all of the J-Series V6 (with the exception of the last few model years with DI). This belt has always been made by Gates Unitta.Not sure about that. Honda dealers list Mitsoboshi belts in their catalogs as the current oe replacement belt. You did say the replacement mitsoboshi is not as well made as the original mitsoboshi and you offer up the unita as the answer.. Cornfused
I will not argue this since it is an incidental side issue to your original comment/response. So once more: how is a replacement Mitsuboshi belt inferior to an OE Misuboshi TB factory installed belt as you originally stated? Not being argumentative but trying to find out from a knowledgeable pro techThat is not correct. Honda specs part# 14400-RCA-A01 for almost all of the J-Series V6 (with the exception of the last few model years with DI). This belt has always been made by Gates Unitta.
When my ASE Toyota mechanic friend recommended the DAYCO kit from PEP BOYS for my sons 96 Corolla I did a bit of head scratching. The w/p was an AISIN brand WITH the cover (those that have done the 1.8 Yota w/p know what this is). The tensioner had Timken bearings, so that was a plus. And all of the seals and grommets were made by VICTOR REINZ. The only parts that were DAYCO were the tension pulley wheel, bypass hose, and belt. Go figure. 🤷♂️I don't think anyone here is concerned about the belts in the kits. It's literally everything else in the kit that people are questioning the quality of.
Show me where I said the original timing belt is a Mitsuboshi? I stand by my comment that the belt included in the Aisin kit is subjectively inferior to the ones sold by Honda. Hold both in your hand and you’ll see. With that said, the included belt seems to work fine for the full service interval.I will not argue this since it is an incidental side issue to your original comment/response. So once more: how is a replacement Mitsuboshi belt inferior to an OE Misuboshi TB factory installed belt as you originally stated? Not being argumentative but trying to find out from a knowledgeable pro tech
My mistake. I inferred from your comment where you said the Aisin supplied TB (Mitsuboshi) is inferior to the Honda OE replacement TB (Yamata)Show me where I said the original timing belt is a Mitsuboshi? I stand by my comment that the belt included in the Aisin kit is subjectively inferior to the ones sold by Honda. Hold both in your hand and you’ll see. With that said, the included belt seems to work fine for the full service interval.
The kicker is that all this parts sourcing can change with the wind. In a way, it's galling.DAYCO kit from PEP BOYS for my sons 96 Corolla I did a bit of head scratching. The w/p was an AISIN brand WITH the cover (those that have done the 1.8 Yota w/p know what this is). The tensioner had Timken bearings, so that was a plus. And all of the seals and grommets were made by VICTOR REINZ. The only parts that were DAYCO were the tension pulley wheel, bypass hose, and belt. Go figure.
I think my OE HiondaTB was Mitsoboshi since it’s an ‘08. Looks identical in every way to the new one I put in about a month ago. The serp belt is Mitsoboshi from Honda and it looks very robust compared to aftermarketMy mistake. I inferred from your comment where you said the Aisin supplied TB (Mitsuboshi) is inferior to the Honda OE replacement TB (Yamata)
Hard pass on the Gates, I don't even like using the Continental kits. Aisin only on Honda's. You'll see when you open the package: the water pump has a pad ground down where the original Honda logo was located. The literally just pull OEM pumps off the line, grind off the "H", and package them in their own kits.
Did you also reuse the idler pulley bolt?Just for anyone who enjoys the market research: I happened to install an Aisin TKH-002 kit in a Pilot this afternoon and can report the following:
Box label stated "Assembled in USA"
Idler and Tensioner pulleys were Koyo from Japan
Hydraulic tensioner was ink stamped "Aisin"
Water pump had Aisin Japan cast in
Belt was a Mitsuboshi from Thailand
Did you also reuse the idler pulley bolt?![]()
I see it available at Napa (in stock at my nearby store too) and a regional chain of auto parts stores but neither Autozone nor AAP have them. Can't even order them to be shipped. This is for a Honda 3.5L too, so a very common application.Yes the Aisin kit can be bought locally. They're sold at all the parts stores. Napa, Autozone, AAP, independent parts stores, etc.
