Gasoline engine H2O of vacuum 4 air filter change
Maple Syrup Land
Recently I got a Wix filter minder and it is rated from 8-25 H2O/vacuum which is meant for diesel engines.
So I am wondering when would I need to change it for a gas engine?
Don't go any higher than 11-15". The filter may bend and fail to hold any higher.. 25" is for diesel engines with turbo chargers. The filters are made to take that kind of drop.
Filter Minders designed for gasoline engines say to clean (I read that as change) the filter when the gauge starts reading in the red - at 10 inH2O:
So, I'd recommend changing yours when it starts indicating just about "11" on your gauge.
HTH
Just use the scale. That's what it's for.
I added the minder that goes to 25".
With 31K miles on the filter it's between 8 and 11".
I plan to change the filter when it reaches 15".
I think 10" is a bit conservative for a "paper" filter.
K&N probably chose 10" for users of their filters, who want minimal restriction.
Originally Posted By: Garak
This thread could almost be a sticky, thanks to the exceedingly useful and concise information here.
Maybe not quite so concise, but this usually gets cited sooner or later.
https://www.fueleconomy.gov/feg/pdfs/Air_Filter_Effects_02_26_2009.pdf
It gives some example restriction guage limits. I could be mis-understanding it, but it seems to disagree with the statements above.
A 2001 Chevrolet Silverado with 5.3L V8 (petrol) moved into the red at about 5.7 kPa (about 22 inches of water)
Two Dodge Ram pickup trucks with 5.9L (diesel) engines moved into the red at about 4.2 kPa (about 16.9 inches of water). i.e. Less than the petrol engine.
The paper says that the restriction guages read the pressure difference between the area behind the filter, and atmosphere.
The 10 inches of water guideline for filter change is an excess, over the pressure drop caused by a new filter.
Unless newer restriction guages can be zero'd with a new filter, (?) which I suppose would be possible, then it seems they don't (or at least didn't when this paper was written) read this excess directly.
