I say: "Get thee to a dyno" so you can measure the exhaust gasses and figure out if you are running rich/lean and then bring the fuel pressure to the proper pressure so that the computer can figure out where to run the engine.
Once you get outside of the range where the ECU can return the engine for emissions and performance (mostly emissions) the ECU can simply give up and run open loop. Most ECUs run open loop at WOT, you run WOT on the dyno, so setting the fuel system right on the dyno will bring the engine back to the point where the closed loop system can control the engine properly.
