Spending idle time, gas choice, some oil.
I don't see enough white residue as leaded plugs can build up.My guess, is this car also running leaded fuel?
+1Looks like rust to me.
Rich usually shows up as lots of unburnt hydrocarbons, in otherwords "black." Soot can also indicate the plug is too cold. I'm asking what specific attribute of this plug screams "rich" or "forced induction"You keep saying this. What do you mean - how we got there.? How do you think we go there? We looked at the plug?
The sum total of the input we received from you is a picture of a plug with 30K miles and indication that all the plugs look the same - ie its not likely a bad plug.
Could be a weak coil - if its an old car with a single coil. I sort of doubt it though. I think it would be black not tan / red.
Your taking all the fun out of this.
I hope this is not something stupid like you ran seafoam or paint thinner.
Carburetor with the float stuck open and pouring smoke yes. I am assuming you didn't run it like that for 30K miles.Rich usually shows up as lots of unburnt hydrocarbons, in otherwords "black." Soot can also indicate the plug is too cold. I'm asking what specific attribute of this plug screams "rich" or "forced induction"
This is what I'm thinking too. Seen it in some of the Mopar performance groups with guys running Boostane.Massive amount of octane booster? (MMT) My guess due to color of the plug.
Plugs were installed 11/16/2024.
Engine is an LQ4 aka 6L Vortec
Vehicle averages about 1800 miles per month.
Plug photo was taken at 155k miles, 31k on the plugs
Engine OCI is on average 3,854 miles
EGR was present for the majority of the plugs lifetime
The vehicle is mostly used for heavy towing
The engine runs in closed loop at all times, 14.68 AFR unless operating in lean cruise, where it dips into 15.5 - 16.7
The reddish hue is coming from gumout regane or techron. One treatment per OCI was performed due to valve contamination for the past 15k miles.
These plugs are EOL and were at the point of causing misfire.
