You've got to be careful on the startup question, going either way. Regardless of the oil type used, the filter is performing a leveling function, pulling out pretty much all the debris above its filtering threshold. Oil A might be allowing a lot more wear on startup than Oil B, but a good filter may mask that difference. A lot of good data gets thrown away with our filters -- how many of us can afford a micro tear-down of the filter on top of a normal UOA???quote:
Originally posted by T-Stick:
In regards to start-up wear, the principle is certainly valid; but there is no data here which suggests it occurs in our normal USA climate in excess of synthetic oil wear. In fact the evidence appears to the contrary in the used oil analysis.
{snip}
We can all easily agree that an engine with a problem that might be aggravated by extended oil use should be run on short intervals. I'd hate to have a syn-only 'vette that fell into that category. . .quote:
{snip}1. There are a number of used oil analysis here above 5k where there were problems. I would not want to drive an additional 10-15k when I had a problem developing at 5k even if it was to establish an initial baseline for testing.
{snip}
I happen to be one of the few BITOG members who has actually run used oil analysis with particle counts. At least in my vehicles and up to 10k miles, this just is not proving to be a big factor. In fact, even at 10k miles, while using a Mobil 1 filter (which advertises especially fine filtration), I've had almost insignificant particle accumulation at sizes over 5 microns, where damage might really become an issue.quote:
{snip}3. The main issue with extended OCIs is not the TBN i.e. integrity of the oil; but rather the unavoidable accumulation of fine particulates.
There is less risk involved when running dino with 5k OCI than running synthetic to 10-20k. I believe that "normally" freshly installed dino at 5k will show less wear on an engine than synthetic with 5k worth of contaminants, during the next 5k, especially when the synthetic cannot show better wear in the first 5k. With extended OCIs there is always more contamination, hence always more risk.
{snip}
Now unlike some other members, I will decline to extend my limited experience to a global conclusion that particle accumulation will never be an issue for anyone. I just can't tell -- yet anyway. But for me, with my 10k oil still clean enough to pass as airline hydraulic fluid, I'm just not too concerned about particle build-up for the moderate "extended" drains which I am using with syn oils. Assuming my numbers are linear (or close to it), I don't see this risk rising significantly until well beyond when I plan to dump my synthetics anyway.
