Originally Posted By: laserred96gt
Forget removing the broken piece, if it is glued you cant pull it out, you are supposed to glue the pipes so the bone head did his job. Just try to cut the pipe with PVC cutters, install a new T and whatever other fittings it may take, they cost only cents at Home De Pot.
The pipe is 1/2" and together it's about 10'long... all glued together. I may just cut it near the starting point so I can get the whole thing out from behind the furnace and the chimney. Then I'll try to do what this guy does in this video.
Then use a coupler when I put it back together.
