Hey all:
This weekend my wife mentioned to me that she started smelling something hot and some investigation showed that the furnace blower was not running. I went downstairs and turned the blower on to "ON" instead of "AUTO" and heard the motor humming, not turning. This is a belt driven unit. I oiled the two oil ports on the motor and got it spinning again. I attempted to adjust the belt tension and found that the bushing (for lack of a better term) that holds the bearing on the shaft of the squirrel cage is disintegrated. The whole unit still works but is very worn out and will need replaced soon. I took phone pictures of the placard on the electric motor and went to my local builders surplus place and bought a used/good condition/tested direct-drive squirrel cage blower fan that matches the output 'flange' dimensions and is also a 115v 1/2hp. I'm wondering if wiring it up is going to be straightforward and if there are any concerns. Both units have a total of three wires, the new one a red, white and black, and to the best of my knowledge, the old one has three unmarked black wires, one of which is obviously a ground. I'll snap pictures when I get home but does anyone foresee any issues making this change? I think the direct-drive unit should be more reliable and I'm also pretty sure with how gunked up the old one is, it's not pushing nearly enough air.
