Originally Posted By: laserred96gt
Doesn't seem like something I would consider, I'm not sure if the main purpose of the valve is to not get oil on your hands but I get some oil spill when changing the filter anyway. Maybe it makes it easier changing the oil in the winter when it's freezing out.
The main purpose for me to use the Fumoto is to control the drain flow and then make it so there is less mess due to using attached drain hose. It really makes a nice feature to take a mid stream oil sample to send in. The location of the drain plug on my 2013 Silverado, if I only used the plug, then oil would stream clear over to the passenger tire. Having a drain pan at the exact location is a guessing game, and even when the pan is placed properly, the splatter effect is more pronounced due to the angle. With the Fumoto, I don't end up with oil on my lower suspension, tire, and driveway. My hands are the least of my concerns. For my semi trucks, dumping 10 gallons of oil, I need to stop the stream a least once to dump the catch pan nto my used oil drum.
It isn't always just about keeping a little oil out from under your fingernails. Not everyone has the same situation.
