It has a bad reputation of high evaporate lossEither one will work. Can you get Total brand oil in Egypt? Their Quartz 5000 will work too.
You will find what you are looking for here … somebody to agree with you. Only they will not be from a motor company or an oil company. There are plenty articles written about oil quaility over just plain thick in high temperaturesThe problem is with ambient temperature 5w wont work in summer maybe i could get away with it in winter but at summer it would evaporate and make the lifters noisy as hell
there are 2 options for 15w50 in Egypt, 1st is mineral oil 2nd is semi-synth we don't have much options for synth oils in the heavy weight oils but Amsoil all of the other brands start with 5w for fully synth oilsNo reason not to use a 15W-50 if synthetic. A 120+ VI Group III, IV or V Base is naturally going to have a wider multigrade viscosity spread than a 70 VI Group I or 100 VI Group II or blend.
Stick with 15W-40, 20W-40, 25W-40, 20W-50, 25W-50, or 25W-60. They will have the thickest base oil and least amount of VII. 10W-60 is one of the worst SAE viscosity grades, as it has too much VII. You don't want 10W-40 in the warm Egyptian winter either, as it has more VII and a thinner base oil than that of 15W-40. Between 20W-50 and 15W-40, typically either is fine. An HDEO 15W-40 will usually be of higher quality than a PCMO 15W-40—same with 20W-50. Stick with name brands.another idea i have is to use 10w60 at summer to provide that extra protection from long exposure to high RPM and 10w40 at winter
Sorry for my ignorance but what is PCMO and HDEO ? as my 2nd thought was 15w40 or 10w40 as winters are becoming colder than before here in Egypt, it used to be warm all year round not its blazing hot in summer and gets real cold in winter '' Colder than what we are used to ''Stick with 15W-40, 20W-40, 25W-40, 20W-50, 25W-50, or 25W-60. They will have the thickest base oil and least amount of VII. 10W-60 is one of the worst SAE viscosity grades, as it has too much VII. You don't want 10W-40 in the warm Egyptian winter either, as it has more VII and a thinner base oil than that of 15W-40. Between 20W-50 and 15W-40, typically either is fine. An HDEO 15W-40 will usually be of higher quality than a PCMO 15W-40—same with 20W-50. Stick with name brands.
VII and HTFS table of selected oils
Can you list the price per quart of few available oils?
If I wanted to or had to dump a 16093 km (10K miles) oil after 4828 km (3K miles), the price would be near the top of my list. At 4000 km oci, you would hope or think most brand name oils on the market should handle the job. Even olive oil should last that long. lol
No?
Mannol safari full mineral oil 20w50 SN rated = 280 EGP per 4 liters ( 4k KM change )
Motul 2000 full mineral oil 20W50 SL rated = 280 EGP per 4 liters ( 4k KM change )
Local brand ( Tawon oils ) full mineral oil SL rated = 205 EGP per 4 liters ( 4k KM change )
Amsoil Premium protection 20w50 = 680 EGP per 4 liters ( 10k KM change )
As per the manual and the oil manufacturer, Amsoil distributor in Egypt recommends 15k interval but i wont go that farAre the 4000 km and 10000 km change intervals something you decided to do or is it in the owner's manual or the recommendation for your new engine? Curious what your owner's manual recommend. I am sure they take into account the heat & dust in your area.
i do change the air filter and fuel filter every 10k to 15k KM maximum shell and castrol here are Egyptian made and filled and both suck imported oils are much better than the local ones we have here '' Mobil, Shell, Castrol '' we have imported oils like Motul, Mannol, Amsoil, Liqui moly all of the imported brands are much better than the ones made locally here
I have owned the car for 9 years now and tried every local made oil and when it comes to castrol they make 2 options for my car 20w50 SG high mileage or 20w50 SL and they both suck equally due to no quality control in Egypt and they follow pricing technique of making the product pricer than it should be to give the illusion its a good product same goes for mobil they make a very pricy mineral oil for 15w50 full mineral oil is priced at 365 EGP as for Shell sadly its the most brand i used to like and use but over the years alot of fake products came to the market carrying Shell's name so either i have to search for a trusted source which might be far or order online which might take time " i do use Shell's 20w50 high mileage oil whenever i get my hands on authentic one " but for my new engine i wanna use the more quality controled oils aka imported oils as quality is a big issue here in Egypt whatever is made locally is never made with high quality as for mobil i am not paying for their marketing campaign or brand name i want a good oil not heavily marketed oiljust read some of your previous posts more carefully ...
If Mobil, Shell and Castrol are made locally and available and they have their names on the bottles and meet a certain spec then how could they "suck"?
don't limit yourself unless you have some insider info or data to back it up and not based on what your mechanic and/or neighbor says.
You are cornering yourself into dino vs. Amsoil and I think you mentioned that money is no object and you want the best ... In that case, your choice is very clear.
Having said that, Amsoil is 2.4x the price of dino so if you go 2.4x4000 (9600 km) plus you save on a filter and labor, you will still be ahead. Cut that (9600 km) to 8000 (almost half of amsoil recommendation) and everyone should be happy and you should break even ... I would take 8000 km with Amsoil over 4000 km with dino anywhere on the planet.
20w50 or 15w40 dino would be fine. Just change frequently and use a quality filter.i have changed my motor from 1300cc to 1500cc as my old engine was done for '' a Mitsubishi lancer 1998 '' the mechanic used Mannol safari 20w50 SN rated mineral oil '' i live in Egypt temp never goes below 10 Celsius and at summer it reaches over 40 Celsius '' for the 1st 1000KM to help clean and test the new engine and it was fine then changed again with the same oil and recommended to change it every 4000KM as our roads are dusty and heavily crowded, i wanna shoot for extra protection i want the best oil i could put into the car i wanna try full synth oil and the only full synth oil that comes in that 20w50 grade is Amsoil premium protection, now the question is should i change for Amsoil and extend the drain interval to 10000KM will it give more protection to the engine component and better flow ? my summer driving is mostly traveling for long long distances on a high RPM while mostly at winter its normal driving, is the change worth the money that will be spent ?
Think it’s passenger car but companies might call it PVL (passenger vehicle lubricants)PCMO: petroleum car motor oil. For gasoline powered vehicles.
HDEO: heavy-duty enginge oil (usually for diesel engines but many are also approved for gasoline powered vehicles).
Passenger car motor oil (API S* spark ignition categories) and heavy-duty (commercial diesel truck) engine oil (API C* compression ignition categories).Sorry for my ignorance but what is PCMO and HDEO ? as my 2nd thought was 15w40 or 10w40 as winters are becoming colder than before here in Egypt, it used to be warm all year round not its blazing hot in summer and gets real cold in winter '' Colder than what we are used to ''
I can use diesel oil in a gasoline car? i mean those oils are diesel oils not for gasolinePassenger car motor oil (API S* spark ignition categories) and heavy-duty (commercial diesel truck) engine oil (API C* compression ignition categories).
That's basically the same climate as here in Southern California, with coldest nighttime temperatures in the winter around 5 °C (41 °F). 20W-XX is definitely fine at temperatures above freezing. 25W-XX would work, too.
You can use synthetic, but it could be a waste of money, especially with short oil-change intervals. I am sure you have quality brand-name mineral oil available there. As I said you may want to go with a brand-name HDEO, especially if you're concerned about counterfeit oil. I can't imagine they are selling counterfeit brand-name HDEO.
You have a plethora choices there, perhaps more than what we have here. 5-liter jug of Shell Rimula R3 X 20W-50 is selling for only 260 Egyptian pounds, which is $16.
أمازون مصر: تسوق أونلاين | أسعار مخفضة على الإلكترونيات، الأزياء، الموبايل، السوبرماركت والمزيد
جميع احتياجاتك متوفرة على موقع أمازون، وجهتك الأولى للتسوق أونلاين فى القاهرة، الإسكندرية وجميع محافظات مصر. استمتع بأقوى العروض، أسعار منخفضة، الدفع عند الاستلام، شحن سريع واسترجاع سهل ومريح. اشترك فى برايم واحصل على توصيل مجاني غير محدود.egypt.souq.com
Now, you've learned something on BITOG. It would definitely work. Shell Rimula R3 X 20W-50 is a full-SAPS oil though, and the main issue is that it may not be the best choice for newer cars due to emission-system protection issues, certainly not for a diesel engine equipped with a particulate filter. For an old engine, it's more than OK. Some HDEO are dual-rated for gasoline engines, such as CJ-4/SM, CK-4/SN, etc., and you can have peace of mind using them in a gasoline engine.I can use diesel oil in a gasoline car? i mean those oils are diesel oils not for gasoline
