Yes, but never got anywhere. I keep going down the rabbit hole of oils which are limited on ash. I have AMSOIL Signature Series in it now. But theor Marine diesel oil looks like a better oil. Looking for other opinions to not go boutique oil.
Torn down too many roller cam failures lately and really wonder if its oil that is the culprit. All of the big 3 have roller lifters fail now. Never used to be that way. Ford, GM, and Mopar all made roller cams which laster 200k+. What has changed? Oils with less additives, and that is happening with diesels too.
Too many rabbit holes and cam failures!
Metallurgy changed.
I just had a cam failure in a fairly new MX13 in my fleet, 2019. We did the tear down this morning at my main truck shop.
I have ~10 other trucks with MX13s. I have about ~40 X15s. A mix of PX9 / ISL, power strokes, some newer Detroit’s and still over a dozen old CAT C15s, some older Detroit’s and Cummins engines.
I do oil analysis on all ~150 pieces of equipment. From 1948 international T6 crawler, 1969 D7, 1956 D4 7u, to a fairly new Case IH Maxxium Pro 140, nearly new Deere skid loaders and excavators.
The oils are generally fine. The surface finish (because of the quenching process) has changed. If anything, oils have vastly improved over the last 20 years - exceedingly so.
But, the quench process has gone down hill. I’ve seen what they call quench oil in Michigan. I can only imagine what they are in Mexico, China, etc.
That’s what’s changed as both, a professional fleet owner, a farmer and… a lubricants engineer.
