JASO DH-1 oil for non-emissions diesel tractor
My new Yanmar tractor specifies an oil meeting the JASO DH-1 spec. T6, my go to oil meets the DH-2 standard which is low ash for diesel engines with DPF. The DH-1 us a higg ash formula for non DPF engines.
What oils are available in the US which meet the DH-1? I've looked for a bit, and coming up empty.
If you can still locate a legitimate CI4 plus/SL pre 2008 it will have a very likely higher additive concentration than what is currently on the shelf.
That would be appropriate for your engine. Just because you can use a lower additized oil currently offered does not mean that it is the best option
Thank you, those are my thoughts exactly
