Originally Posted By: disturban
Lower Cold flow properties would also mean less oil on the gears at initial start up? A thicker oil would stick to the gears.
If we was talking about motor oil you would want the cold flow properties but I dont know about gear oil?
No, the opposite. All oils run off and "stickiness" is not a property directly related to viscosity.
