GL-5 rated 90W search
Central Washington
You can use any 75W90 or 80W90 GL-5 gear oil.
If you want a syn. I recommend
It comes with additives for the LSD.
I've been searching for a GL-5 rated 90 weight gear oil although other than a 10oz. tube for O/B motors lower ends, I'm coming up empty. This is what is spec'd for my LSD rear differential on a 04 Toyota Tundra. I'd really like to use a syn fluid but I can't even find a dino fluid. Any ideas out there??
Motoretro
If you want a syn. I recommend Amsoil SVG
Onmo'Eegusee - thanks for the recommendation. While I think the SVG 75W-90 will work (but will need the LS additive) the SVT 75W-110 above is a better match. Plus, just as a reminder, those links need to be from an Amsoil site sponsor - if purchase happens through your link, some random Amsoil weenie will get credit.....
I usually just use what is available at the local stores + the LSD additive neede by the LSD.
ANY 90wt(75w90, 80w90, SAE90) will work well.
Toyota diffs aren't fluid picky. But, their LSDs are definitely additive picky. I would say that most brands of fluids require an LSD-additive dosage. Lack of LSD additive is the cause of ALL those anti-synthetic posts concerning noisy rear-ends when switching fluid types.
If you work the truck, upgrading to a 110wt or 140wt is a smart move.
Originally Posted By: Pablo
Use a 75W-110. WITH the LSD additive.
Amsoil SVT 75W-110
Amsoil Slip Lock
The reason for the 110 recommendation is that is is closer to old style SAE 90.
http://www.lubrizol.com/products/automotive-gear-oil/J306.asp
The SVT 75-110 sounds good. I'm going to check in my local area for Amzoil dealers tomorrow although if i can't find anything do you ship? I'll need 4 qts plus 2 bottles of the LSD additive, I believed its called slip-lock or something like that.
Thanks for the help guys!
Motoretro
Motoretro
Amsoil ships from your local warehouse. Low cost shipping and very quick. Please order from my link or website so my funds go back to support this site. Some local dealer won't do that, nor will he likely have 75W-110.
I am using LE 607 (SAE 90 GL5 mineral) in my 2000 Tundra rear diff. This gear oil has been reformulated and is now a synthetic blend called LE 1605 (SAE 110 GL5) now. I will either try LE 1605 or AMSOIL SVT 75W110 next. Haven't decided yet, but I have a couple of years to evaluate feedback from these two new products.
