Been there, hence if there is a air leak I can’t find it, the intake on these, bolts in vertically and there is a 2 parter to it where it comes apart in half. Which also sits vertically. I’m running out of cans of brake cleaner and carb cleaner, lol
And just to confirm, no codes?Been there, hence if there is a air leak I can’t find it, the intake on these, bolts in vertically and there is a 2 parter to it where it comes apart in half. Which also sits vertically. I’m running out of cans of brake cleaner and carb cleaner, lol
Erase code by battery disconnect or by scanner clearing codes. I do it once a year with my scanner. Did you change oil. Last oil change at dealer made my fuel trims go all over the place.Unplug maf sensor, start car for 5 second, turn off car. plug maf sensor back in, clear maf code. Start car and voila.
Oil is only 1000km on it, however it has a reddish hue to it which googling it appears to be a normal thing,I was hoping it was not injectors, whole intake has to come off for that, possibly too much fuel pressure as well I guess which would be easier to test first.
No code
Does the Oil smell of gasoline?Oil is only 1000km on it, however it has a reddish hue to it which googling it appears to be a normal thing,
LTFT at -5% is well within normal range.Im unable to record, so as it stands, Ltft is -5% and stft is -12% at idle and at 1500 rpm’s ltft is 0 and stft is -18%. Upstream 02 sensor is oscillating normally from .03 volts to .88 I put a new one in, and down stream 02sensor is at 0.16volts constant.
Ok, great. It could have been a lazy 02 sensor as once I changed it today , Ltft went from - 12 to -5%LTFT at -5% is well within normal range.
STFT data is meaningless data. The fact that its moving all over the place means its working.
Also, the negative LTFT means the ECU is taking fuel away hence It can't be a vacuum leak. Vacuum leaks add unmetered air into the system, so you would be running lean, and the LTFT would add fuel by going positive - ie your fuel trim would be +10% or whatever.
+/-5% LTFT is what you want.
It does not, however if the bad 02 sensor was causing a rich condition it could have degraded my oilDoes the Oil smell of gasoline?
Don't overlook low fuel pressure.Hello all, nissan 06 xtrail 2.5l. Trying to figure out a issue with these fuel trims at idle.
Ltft -10%Stft +8 to+13% with a short blip every 10 or so seconds of -100%. Upstream 02 sensor oscillates but hangs out more in low voltages even going below .1 volt to .04 volts. Thoughts?
Symptoms are hard start when cold- 20 and pinging from engine when cold while driving until it warms up a little.
His fuel trims were taking fuel away (negative). If fuel pressure was low I would expect it to be running lean, hence he would have a positive LTFT to add fuel - longer pulse width. I think his issue is sticky or clogged injectors, or a bad sensor somewhere.Don't overlook low fuel pressure.
