Fuel tank sealer
Hello community,
I need some advice from people who has knowledge or experience dealing with fuel tank sealers.
I've got an oldtimer car (I think that's called a 'classic car' in the US) and I'm having problems with fuel tank.
Long story short, I am on 3rd fuel tank right now. All of them are suffering from internal rust and eventually they start leaking gasoline.
To make matters worse, the fuel tank is located inside the cabin so once it starts leaking, you feel strong gasoline smell and diziness is felt too.
The original tank I removed from the car was so bad that there was nothing to weld/solder. Entire bottom was rusted and I found millions of small holes after pressure washing it and flushing all the rust out.
The 3rd tank, which is installed now was given to a local tank & radiator specialist to identify problematic areas and fix it. So he did some soldering (or welding? IDK) on it. One year later, the tank developed a leak, and I think in the same spot where it was repaired.
I managed to find a used fuel tank in fair condition. It contains some rust inside but nowhere as bad as my previous tanks were. Since replacing the fuel tank in this car is a PITA, I'd like to do it the last time, that's why I want to use some tank sealer before the installation.
Since I'm located in the middle of Europe, finding some professional-use chemicals is next to impossible. Best what I can find is some epoxy for 'emergency fuel tank repairs' but that's not what I am looking for.
So I decided to look for US-made products. What I found so far are those:
1) POR-15 Fuel Tank Sealer
2) Red Kote fuel tank sealer.
I also came accross some other less known products but they had mixed reviews so I decided to skip those products.
Does anyone have any experience treating old fuel tanks? Which product should I use?
The tank itself is 45 liters / 12 Gallons in capacity, yet it has a bit complex shape - 3 baffles inside and filler neck goes a bit deeper into the tank making some kind of barrier if you put the tank upside down (not all fluid contents spill out in that case; not sure if my explanation is clear). Also, I need a sealer which would be resistant to high ethanol content in gasoline.
POR-15: Pros - good reviews, available for purchase in UK so that I can order it easily. Cons - very expensive, considering I'd need somewhere between pint and a quart of actual sealer
Red Kote: Pros - not too expensive, comes in a quart can which should be sufficient for the job. Cons - unavailable in UK or Europe, shipping it from US might be problematic/impossible.
Any input highly aprreciated.
Thank you
How big is the tank? If it's small enough you can put a couple dozen 10mm nuts inside the tank, block the fill opening, wrap it into a ball with taped on towels, and tumble it without heat in a clothes dryer for a few hours to clean up the interior. I used to do it all the time with neglected motorcycle tanks.
I had the best luck with POR-15 tank lining - follow the instructions! - because the inside of the tank wants to be clean.
If external appearance is not overly important you can coat the exterior with Gluvit - which is a marine epoxy made by Marine-Tex.
Also: you can make a new 'tank' out of 1/4" galvanized hardware cloth and cover that frame with fibreglass cloth and Gluvit. Epoxy on the fill and fittings and Bob's your uncle.
