Should be able to read it with the appropriate software then. Anyone want to show us the data with the tank full and also with it almost empty?Moat newer cars should have a fuel temp sensor already.
Ya, stupid diesels.*Some*
My TDI isn't. Compression generates heat. You can watch the fuel temp climb the longer you drive it. It climbs higher the lower the fuel level gets in the tank.
Not every car on the road is brand new or the same.
I have to fill up today so I'll try to get some info. I won't run it below a quarter tank though.Should be able to read it with the appropriate software then. Anyone want to show us the data with the tank full and also with it almost empty?
Same. I think the system could be cleaned properly, but it would be too labor intensive for a shop and would end up costing more.Ya, stupid diesels.
This is why when the HPFP fails on BMWs, we have to replace EVERYTHING the fuel touches. Right from the tank to the injectors.
I've used the fuel pump to pump down tanks and anything past an 1/8 of a tank is also pumping air.I suspect pump cavitation occurs more when fuel level is extremely low and depending on driving style and conditions is what causes the failures.
What is a "dead head" system? How is it converted to a live system?I hate dead head systems and often convert to live to run a cooler fuel to the injectors .
No that heats it.A pump is cooled by fuel running through the inside of it.
Before filling, after sitting for 4 hours after my 35 mile commute, then the lowest the temp fell after filling with 24 gallons. (~5mi), then the ending temp after the remains 30 miles home.Should be able to read it with the appropriate software then. Anyone want to show us the data with the tank full and also with it almost empty?
On a cell will explain tomorrow when I get my new computer. My hard drive just failed an hour ago. So I had to remove the hardrive and pull my info for the new computer. It was its time after 5 years anyway.What is a "dead head" system? How is it converted to a live system?
Simply a non-return system where the fuel goes from pump to injectors and that's where it stops. Most cars use a system where the fuel goes from pump, to injectors, to a fuel pressure regulator which bypasses fuel back to the tank in order to maintain pressure. This requires 2 hoses, one up and one back.What is a "dead head" system? How is it converted to a live system?
If you are getting condensation in the tank, you have bigger issues. It is a sealed system.The fuel pump relies on surrounding fuel to keep it cool in operation. Run it low, it's above the level of the fuel, starts getting hot, prone to excessive wear or even seizing. It doesn't cost any more to just keep the tank full, or close. Less condensation in the tank that way too!
Not in diesels-many of the issues we had with diesels were caused by running them low & freezing fuel lines or growing fungus in the tank. Fuel gets hot from return fuel or ambient temps, cools overnight-how does the tank not collapse? Most fuel systems have a one-way valve somewhere, to allow air IN.If you are getting condensation in the tank, you have bigger issues. It is a sealed system.
I always thought it was bogus until I had my Mk6 GTI for about three or four years (bought new) , I used to always run the tank right down to nothing about once a week, and the fuel pump died really early, at like 45-50k miles or something. So it's an anecdote but I certainly believe it more now.
I only run my cars with mechanical pumps low on fuel. When I worked in the auto service industry it seemed like almost every fuel pump failure was either on an almost empty tank or 100% full as they just filled it up. I was told it often happened immediately when the cold fuel hit the overheated pump.Meh, maybe it's a problem with certain pumps and not others. In over a million miles combined I run all of my cars down to near empty every tank and even my 25 year old Accord and my 22 year-old Sienna (with over 450,000 miles at this point) have their original fuel pumps.
I also never use any sort of aftermarket fuel additive nor do I watch when the tanker truck is at the station.
