fuel pump? on the chevy truck
Well if it's not one thing it's another. I get home to work on the ac of the truck just charging it. Well I ended up also fixing the connection to the headlight. So i unhooked the battery. Got done hooked battery back up and won't start. Fuel pump isn't kicking on. So i check the connections u derby the hood the relay wire and fuel pump fuse wire. Everything has power. So i checked for power after the Inline fuses still have power. The fuel pump primed two times out of a bunch of times turning the key. It has good spark as well. So my guess is since the fuel pump isn't kicking on but every once in awhile it means the pump is bad? Does that diagnosis sound correct?
It seems likely enough. Can you start the fuel pump by whacking the tank with a hammer? When you can get the fuel pump to prime, are you able to start the engine?
I smacked it with my hand and it would run sometimes but still won't start.
Try some starting fluid while cranking. If it fires, then it could be the pump or wiring to the pump (possibly a ground).
I wouldn't hit the tank with a hammer.
Did you check the "auto run" relay?
Where is that at? I pulled the cover on the fire wall that said fuel pump fuse, and relay
Hang on now. Are we talking about the Dodge or the Chevy? The Chevy doesn't have an "auto run" relay. Either way, if smacking the tank made the pump start it's time for a pump.
I've had a few Chevy trucks. I had a 96 with a 5.7L. It's was a 3/4 ton. Fantastic truck until the entire dash shut off on me and buying everything from the wrecker was more than I paid for the truck.
Anyways every Chevy fuel pump I've ever had to replace whined a high pitch for months before failure,so was it whining prior to this.
Have you checked out the fuel filter? A 99 silverado fuel pump is fuel filter/fuel pump all in 1. Talk about swearing my head off n
I think on my 96 the fuel filter was under the passenger side along the frame.
Is the tank plastic or steel. Could the screen be blocked by a rust flake.
On my 99 silverado my fuel pump lasted for 250k. It whined for about 50000 so it gave me ample warning.
Chevy truck of course the dodge runs lol it'll never die....probably shouldn't have said that.
That era chebby usually uses the oil pressure switch AND relay to run the fuel pump.
The computer primes the pump with the relay, then the oil pressure switch continues to hold power to the pump once it's running.
Long story short, try the starter fluid and or cranking it for ~20 seconds, enough to build up oil pressure.
A '99 should have an inline filter. I think it was around '03 or '04 that they did away with the externally mounted filter.
Either way, fuel injected GM trucks are notorious for burning up fuel pumps. It's almost an expected expense over the lifetime of the truck. Odds are this isn't the first one it has had, and most aftermarket ones aren't great either. If they put in an Airtex or Spectra a few years ago it's entirely possible it is burnt up again now.
Nope. 99 was the filter in pump combo,then in 2000-2004 they were externally mounted again.
I changed it myself so I'm absolutely positive that my 99 silverado had a pump/filter.
Your 100% correct about Chevy burning up fuel pumps in the trucks. A chev/gm truck of my vintage uses gasoline to cool the pump,so driving around with 1/8 or less of fuel prematurely ages the pumps and cooks them.
My 99 will never have less than 1/4 tank ever again. I've got 80k on the latest pump and no whine yet,but never ran it lower than 1/4 either since either.
Weird, I did not know they first tried that in '99. I knew for sure I had changed external fuel filters on GMT800s before.
I wonder what prompted them to try it in '99, then go right back to the inline one in '00.
I did the fuel pump in my 93 Suburban 3 times.
You may need to use PB Blaster on the fuel line connections to get them undone without snapping the lines on the fuel sender assembly.
Use an AC-Delco pump.
Use a new sock with the new fuel pump.
Glad I sold the Suburban. I hated doing the fuel pump.
Originally Posted By: crazyoildude
we can guess all day.. Check the fuel pressure first and go from there
if the pump isnt coming on the pressure is irrelevant. Pump not working equals no pressure
I replaced the pump, but cannot get the tank back up enough to bolt back up. I still have some fuel in the tank that my siphoning tool wouldn't get. Advice is welcome.
Use a longer bolt or some all thread with a nut on it. The strap has taken a set, bent not right. Once you draw it in, put the old bolts back, one at a time.
