Fuel filter brand quality.
USA
Hi All,
I'm looking to replace the fuel filter on my Cavalier with 156k miles. Members talk and compare oil filter construction and quality all the time. Has there been any consensus or data on various fuel filters ie. Carquest, vs Fram, vs AC Delco, vs OEM? Any thoughts on quality. Thanks.
You're right, I cannot recall any consensus or data....not even much conversation!
AC Delco leaves me feeling good. I put a Motorcraft on my Ranger.
The '99 Volvo which had a serviceable fuel filter got a Hengst? ...or whatever FCP or eEuroparts or IPD had.
Only thing in common was that I applied a whisper of silicone grease on the male connections before shoving them in as squarely and "one clean shot" as I could.
Owners of cars with the GM 3800 V6 motor used to swear by the AC Delco fuel filters. I buy the clearance ones at RA for my 1990 Buick. There are probably only 2 companies who really manufacture that filter for your vehicle, everyone else's is a rebranded product. The AC Delco fuel filters I used to buy were always stamped "Made In Israel", does that make them Kosher?
I'm not overly impressed with some AC Delco parts for a vehicle of that age (since I drive a 1999 Oldsmobile), and a fuel filter would be one of those. I would take a Motorcraft if one is available (and it most likely isn't) just to get the vastly superior case. The cheapest reputable brand (Fram/Purolator/Wix/MicroGuard/Ac Delco) is going to be fine. I would be more concerned if there are plastic clips involved that will need to be replaced and if that is a possibility, buy the filter that comes with those.
Fuel filters are there to remove contaminants that shouldn't be there in the first place - unlike a oil filter that removes normal wear material. So its not really comparable. I think most fuel filters use a treated cellulose - which is likely fine because very small particles shouldn't cause much problem.
I guess you could buy one and cut it open. If it was to your liking buy another like it?
I haven't had a car with a fuel filter that was replaceable (without dropping the tank) in a couple decades. You may not have a lot of options.
You ain't kidding!
The 15 year-old fuel filter from my Ranger appeared to be made of bullet-proof stainless steel.
I forget how I got it open ...but I just had to see the element.
By default I always go OEM with a fuel filter and a air filter IF a OEM is handy to find. Main reason I guess is I had a fitment issue with my many retired Police Crown vics. Only the Ford filter was i assured it was sealing up correctly when putting the filter housing top back on...
I stick with Mann filters although I now see them being made in south Africa. Dunno if quality has dropped since they were made in Germany but price sure didn't drop
