Fuel economy, why has it not improved more?
North Carolina
Food for thought but with today's technology one would thing we would be a lot farther along with fuel economy than we are. Case in point. My 2002 Silverado with a 5.3 4x4 extended cab gets on average 16mpg, If I want I can get 19 but that is keeping it at 55mph and taking it easy. Spring forward to todays new GM vehicles with direct injection and 8sp transmissions and they are only getting 20mpg. To me that isn't much of an advancement in economy. Come to think of it, my dad's 1977 Chevy 1500 stepside with a three on the tree and a 350ci engine got 15mpg. Funny, a three speed and a carborated engine getting what modern tech is getting today.
Another point was when I had my 91 VW Jetta diesel, I was getting 50mpg out of it as well as when I had my parents old 1979 Rabbit diesel it got 50mpg. Granted I know that emissions have a major play in what diesels get now but seems to me one would thing we would be getting the same mileage on an average mpg on new diesels more so than not. My Cruze diesel gets consistent 45mpg but I have been able to get 50mpg if I really hyper-mile.
Just seems odd that we are no farther along than we are when it comes to economy.
I said the same thing when my 00 Century would log mid to high 30 mpg numbers when we'd run it to Fort Lee VA from NY. There are a lot of new 4 cylinder engines that can't do it, and lets keep in mind the size of an 00 Century.
Good question why didn't VW build their prototype diesel they built in the 80's that delivered over 200 MPG? I guess it would have never sold.
Competing regulatory demands.
As I understand it, and I reserve the right to be wrong...
1. We've regulated NOx levels such that you cannot use a lean burn technology.
2. Safety demands, we've set up standards such that you need more safety equipment, multiple air bags, ABS, Traction Control, higher belt lines to help pedestrians, and who knows what else. This drives up the weight in cars.
3. More standard equipment. Back in the 70's and 80's, A/C, power windows and door locks and so on were optional. You could really build a 2000# car. Today, it's hard to find a car that is less than 3000#
4. Even more equipment invented. More power/heated/cooled seats, satnav/infotainment, and who knows what else. That also drives up weight. Add on the bigger wheels and tires that are fashionable today. Try to find an econobox with 13" wheels. Other than maybe that tiny Mitsubishi offering, I don't think there is much new on the market that might even have such small wheels and tires.
All of the above conspires to keep fuel economy from rising.
One other thing to consider is the testing today is more accurate compared to the numbers we saw in the 70s, 80s and 90s. The EPA has revised their methodology a few times. So it isn't even and apples to apples comparison to compare older EPA numbers with the numbers we see today.
That pretty much sums it up. Cars are so much heavier than they used to be - even a compact car has gained over 1000 pounds in the last 20 years. And the EPA doesn't like lean running engines ... gotta keep those cats glowing!
laws of thermodynamics. The Otto Cycle gas efficiency has limits. There is the more efficient Diesel Cycle. Those are the only practical power cycles for cars.
Efficiency has come a long way. Equivalent engine efficiencies have risen 1/3 since the 70s
Size, weight, higher speed limits, congestion, and impatience are a few that come to mind.
A speeding Prius isn't efficient. Honda Civic is now a midsize car. Etc...
Guess my experience is different. Compared to their 1999 and 2005 sedan/SUV equivalent predecessors my current vehicles are at least 20-25% more fuel efficient. Plus they're quieter, handle better, accelerate at least as well, have tons more safety features and technology, etc. They also have more fuel dilution, though...
Something we are forgetting though is power output. Yes it's getting similar fuel mileage, but the power has doubled in some cases. My old 7.3 Powerstroke gets 16-17 mpg and my brothers 6.7 Powerstroke is slightly less (mainly due to how he drives it), but makes double the horsepower, more than double the torque.
Americans want power and speed. The old cars you mentioned take roughly 20 seconds to get to 60 mph, and 65-70 mph is about their top speed. The modern vehicles you mentioned can accelerate at least twice as fast and have about 3 times the power while STILL getting better mileage. AND they weigh significantly more due to all the safety features. If people were willing to live with underpowered, slow vehicles, then sure, maybe they'd get significantly better mileage. But the automakers will only build what people will buy, and nobody would buy a car like that.
Java has it covered. My Wifes old 198? carbureted Dodge Colt 3dr hatch she had when we got married in 1991 weighed under 1 ton had a wide RATIO 4 speed manual and averaged 37MPG. I'm sure HP was under or around 80 MAX.
CATS require soich or richer A/F NO LEAN BURN for NOx limits.
Sub and Compact cars weigh at least 500- 800 lbs More than in the 80s given added safety requirements of 10 air bags and improved unibody structure and then them dooh daads.
Large diameter wheels suck gas and slow the car during acceleration
Much wider tire footprints suck gas. IIRC the colt had 155-70r-13 or close to that.
Finally Much higher specific engine output with torque produced at higher rpm.
Todays 2L 140 HP eco car could RARELY be had, and then only in limited. special H.O. variants
My lowly 4 cyl Nissan Rogue makes more TRUE HP than my mid 80s Mustang 5.0!
Not the whole reason, but food for thought:
"Emissions" isn't always conducive to max fuel economy.
Neither is a thing called *amenities*. How were those old VW diesels equipped, and how much did they weigh? The gas Cruze weighs something around 3,300 lbs. empty, not to count the weight of the diesel engine when equipped - within 150 lbs. of what an early, 4 cyl. XJ Cherokee (let's say, in the same segment as an Equinox today) weighs. Traverse weighs 4,800 lbs. where my '67 Suburban with the biggest optional engine, heavy arse, iron 4-speed transmission, and HD suspension, etc. weighs 4,600.
Air bags, entertainment systems, air conditioning, power windows, extra mufflers/resonators, sound deadening material, etc. - they all weigh something. Add them up, along with the increased heft of the structural components to meet safety standards or have the best tow rating in its class, and it makes a difference.
If the 1.4T in my Cruze can get 37 (easy) to 40 (near perfect conditions) pushing its 3,300 pound shell with a high hoodline for "pedestrian crash" safety down the road, what could that same drivetrain do in the shell of an equivalent car of, say, 30 years ago? (Corsica, Citation, Jetta/Passat, Accord?) Food for thought.
I will say in the Compact SUV segment Subaru has found the secret formula - My wife could EASILY get over 33 MPG AVE in a "largish" Forester with a 6 speed stick and AWD. That is an achievement.
The last Subaru EJ253 used intake tumble valves and a "VTEC-like" variant that mainly used only 1 intake valve at light throttle and low-mid rpm. BUT the Engine still made 175 HP at high RPM when the aggressive cam profile came into play. Brilliant.
I think weight is a huge factor. I had a 2003 Cavalier 5-speed. The only option was air conditioning. I think it was rated for 31ish highway. I could easily pull over 40 highway. That car had just about zero fuel saving technologies like cars today have. Of course I would much rather be in an accident in a modern car than that tin can.
As stated above, we're seeing far more impressive fuel economy for the power, safety, and weight of modern cars.
Here's a little anecdotal comparison in my own experience.
My 1993 Toyota Pickup: 4x4, 5 speed manual, extended cab, 2.4l 4-cyl, 114 hp, 140 lb/ft. torque, 3,530 lbs. I got an average of 18 mpg with a high of 21.
My 2016 Frontier: 4x4, auto, 4-door, 4.0l 6-cyl, 261 hp, 281 lb/ft torque, 4,437 lbs. My average according to fuelly.com is 20.1 with a high of 22.
I'd still like to have my old yoter back...
If it was only about fuel economy, we would all be driving diesel smart cars. Had one by the way, was amazing, except for the transmission.
My best full tank on that car (and it was making more than double the stock power), was 2.9L/100 km, which is a little over 80 MPG.
I've wondered if I get better gas mileage than the people that beat me to red lights. As I approach the red light it often turns green and I have to keep moving at about the same speed. I don't get the chance to come to a stop.
I do see why some people race to the red light. They have to answer a text message and they can type a little faster at a stop light than when driving. Others will honk for them when it's time to go.
For best fuel economy you want to accelerate fairly hard and get to a constant speed. It is only while driving a constant speed to you get decent efficiency. I see people who accelerate very slowly, but constantly and never cruise at a steady speed. Those drivers will get terrible economy. But you are doing it right, time your speed so you don't have to slow down and maintain a constant speed.
My F 150 gets about 17 MPGs around town and 23 to 25 Mpgs in the freeway. My daughters 2010 Focus with an auto gets 32 to 35 mpgs .I had a 92 Toyota 4X4 with a V6 that got no better that 20 on the freeway usually 17 to 19 mpgs.
