05 Subaru Legacy 2.5L 108k
04 Nissan Maxima 3.5L 89k
Original owners of each. No issues either car...
Just changed PP in Subie and added Techron to fuel.
Nissan runs Mobil 1 0W40. will add Techron in 3k.
After reading many reviews and opinions:
Finish a bottle of Lucas Safeguard just used in Nissan to hopefully undo Ethanol damage in both cars 1oz/5 gallons.
Then use MMO 3oz/10 gal both cars every gas fill.
Techron at each 7500 OCI for 1 gas fill
Lucas Safeguard 2oz/10 gal in the winter.
Use Shell for the Nissan. Will try to convince her to use Shell instead the generic Rutters behind the house. No other top tier anywhere nearby.
I will not mix any of these. Most often MMO, then Techron if oil change, and Lucas in the winter.
If MPG falters, will use 2oz/10 gal MMO. Or it improves try suggested 4oz/10 gal MMO... and alter as it goes. Hoping 3oz/10 works.
thoughts?
stocked up on bogo techron; lucas, and MMO with the 40% off ccabin with AAP. Is techron every 7500 enough? or should I also mid oil changes?
Thanks
thoughts?
Thanks
