Yep you need to change your driving style for better fuel mileage. Cleanmpg.com is good website to learn the basics. The owner Wayne Gerdes holds a number of Guinness World records for fuel mileage.Drive style has bigger effect.
--fuel additives are ok, it will clean & protect the system.I wanna try some European fuel additive for a diesel car. Is there Any brand you experts can recommend?
Just for better mpg
Almost 2500 miles or over 1200 miles on a tank of fuel ? I'm looking for more information on this 'cause I don't believe it. Found it 😳He drove from San Diego to Jeckle Island Ga. stopping only once for gas and still had fuel in the tank.
Plus those supposed fuel economy improvements are typically based on some sort of cleaning of deposits that are detrimental to mileage. They aren’t reforming the fuel or some other sort of thermodynamic magic and providing higher energy density. If your engine doesn’t need cleaning or need the specific cleaning the additive is predicated upon then the additive isn’t going to do anything.--fuel additives are ok, it will clean & protect the system.
but this will not improve mileage as much as you think.
Won't improve, but restore mileage to near new car mileage--fuel additives are ok, it will clean & protect the system.
A fuel additive may clean things out a bit. Injectors for example, which may improve the running/operation which in turn should improve mpg.I wanna try some European fuel additive for a diesel car. Is there Any brand you experts can recommend?
Just for better mpg
Stanadyne, blue bottle.I wanna try some European fuel additive for a diesel car. Is there Any brand you experts can recommend?
Just for better mpg
