Frontier Matic J or S?
FL - Florida
Hello all,
I'm about to do another flush and fill on my 2013 Frontier w 5 speed auto trans. The manual specifies Matic S, but Matic J may be used if S is not available.
the S is supposed to be "fuel efficient" and as I understand, it is a thinner fluid.
Would there be any perceived benefit to changing to the J formula? (better protection, more positive shifting, or towing performance etc)
I posed this question to Amsoil and they tried to discourage use of the J formula (their red bottle trans fluid)
any input is appreciated.
manual excerpt:
"Use Genuine NISSAN Matic S ATF. If
Genuine NISSAN Matic S ATF is not
available, Genuine NISSAN Matic J ATF
may also be used."
Nissan 5-speeds technically are spec'd for Matic-J but Nissan moved to Matic-S for 7-speeds and seem to just want to deal with one fluid. S is backwards-compatible with J so that's why they list it this way. S is synthetic, while J was not, and S is also considered low-viscosity. No harm in using Matic-S and Matic-J is harder to get nowadays, I thought.
Castrol Full Synthetic ATF can be used in place of S or J. In fact, you should be able to use Castrol Import Multi-Vehicle ATF too.
Originally Posted by baitbuster
Hello all,
manual excerpt:
may also be used."
NissanMatic S is a virtual clone of the low viscosity ATF. DexronVI. Valvoline DexronVI, MaxLife ATF, Redline's D6 ATF or Amsoil's ATL meets the NissanMaticS specifications..
If there is anyone who you should listen to on here it is... MolaKule. Seriously. Take that to the bank.
On my 2012 Xterra with the same tranny I used Castrol IMV, used it in my 03 Pathfinder as well.
Nissan transmissions especially the 5 speed are by far the most easiest and takes any fluid Dexron clones with very little fussing.
Any fluid that I threw at it when I owned one was always red when drained - beautiful transmissions.
