Front passenger inside door handle 'loose'
Charleston, South Carolina
06 Hyundai Elantra limited, 98,3xx miles.
The front passenger door inside handle is loose, making it harder to open when pulling the handle.
2 questions:
Is something like this covered under warranty?
If not, how would i fix this myself?
Thanks.
Warranty ha at 98k miles and 9 years old!
You DIY however taking apart the door requires some careful work to not damage trim/fasteners in the process.
Originally Posted By: dan765
Hyundai
found the problem
Quote:
Thanks.
You're welcome
It's a 10 minute job. Remove the screws that hold the door panel on, usually at door handle, bottom of door, or behind a light in the door. Then pop the door panel off and tighten the handle.
