The window went down and now will not come back up. I can hear the motor run in the up and down position. But cannot see the window. I assume something inside broke or fell off. If I can get it apart I am sure I can fix it.
However I hate fooling with the inside door panel. I see a few screws hidden by caps towards the front, but none towards the back. So questions.
1) Do I any special tools to get door panel off?
2) What about the door opener handle and lock. Does that need to come off first?
3) Are all the electrical connections on a plug so I can totally remove the door panel and store it.
4) The large padded handle one uses to open/close the door, can that stay attached and left alone? (Basically is it screwed through to the door or only the door panel?)
Really wish is was not cold out.
