As the title states I need to disable the SIR system in my 2009 Buick Lacrosse.
I made a boo boo today. The car has sat for two years while I have been away and there's quite a bit of work that needs to be done to it.
I replaced the drivers outside door handle today. All went well until I put the door panel back on. I checked the outside door handle first, door opened. Pulled the latch cable, door opened from the inside. Then I put the door panel back on and it wouldnt open up from the inside or outside. It appears the latch cable is stuck.
I have to remove the drivers seat to get the door panel off from inside the car but it says online I need to disable the airbag system first.
Is it as simple as disconnecting a battery or a fuse or is there a procedure I need to follow?
