1. Many Mercedes dealers won’t touch a 17 year old car.Take it to the dealer. Let 'em diagnose it and give you an estimate.
2. Minimum diagnostic charge is $250 if they do.
That’s how I tested it exactly. No movement to note.Have someone firmly press the brakes, goose the throttle in drive and reverse. See if the engine looks like it's going to jump out of its craddle.
lol not exactly diy-centric then, is it?Take it to the dealer. Let 'em diagnose it and give you an estimate.
I don’t think that this audit is necessary to answer a simple question on practices to diagnose a clunk.How many miles on the ODO ????? Was the original owner a kid or cabbage patch ???? Garaged or left outdoors most of the time ???? Any maintenance records ????? Any bodywork / repainted nose or fenders ???? Check for ocean waves in the body,,,tell tale sign of bondo., or use a magnet in different areas....,,no grab....bondo under paint........... More info needed on it's 1st life. That will help point everybody in a better direction.
This video may be of help. Jack the wheel up and turn the wheel by hand left and right, listen for clunking or movement in the cv axle, it should be tight. These are extreme examples but you get the idea. Wear in the roller bearings cause noise, wear in the housing will usually show itself as a vibration. I usually rebuild them with GKN (OE) parts and boots as new axles for some of the old Saab cars are scarce.
Actually, the year and model number were the first sentence in the first post.That was not an audit. Just an information question. This car may have come from some kid who beat the daylight out of it for all we know, or a flip from an accident. Don't get so upset over it. But, BITOG's need some basic info to start from. A " simple clunk", could be a million things. You didn't even give up the year of the vehicle. We don't have crystal balls, nor have the car in front of one of us to diagnose. Being you're insulted by the questionair, take it to a dealer and pay the piper.
This is my 2008 ML320.
When I got it, I knew it needed shocks/struts, brake lines, etc. but the rest was pretty good.
I’ve replaced sway bar links that got rid of one rattle, and I did the struts, strut mounts, springs, and shocks.
Still, and perhaps getting worse, I get a clunk when I change from deceleration to acceleration.
For example, driving in a neighborhood, if I brake reasonably hard to a stop sign, then start going again, I get two clunks from the front left. It seems if I steer left it’s more likely to happen. If I decelerate gently, don’t use brakes, or turn right I don’t seem to get it at all.
Doing a hard left turn, like a k-turn can cause it to happen as well as the wheel is turned relatively hard left.
Every joint looks fine. Every boot clean, dry, no rips. I’ve tried jacking up to check for ball joint play and nothing. No play at all in the suspension that I can find. Aligned to spec.
So what can I do to test, and how do I diagnose this? LCA bushings all look fine. Could it be a transmission or engine mount? The transmission shifts smoothly, engine has no vibration at all.
How do I diagnose?
Thanks!
I called a local MB dealer last week for a diagnostic on my 2002 W210, they said they do not have any mechanics who can work on a pre-2005 car.1. Many Mercedes dealers won’t touch a 17 year old car.
Crazy. Wonder if that’s because of obsolete computers for diagnosis, or what. Most work doesn’t change between a 50yo car and a modern one.I called a local MB dealer last week for a diagnostic on my 2002 W210, they said they do not have any mechanics who can work on a pre-2005 car.![]()
Reminds me of one of my favorite "Car Talk" moments when Tom & Ray would be stumped on a diagnosis, one of them would ask, "what color is the car?"I don’t think that this audit is necessary to answer a simple question on practices to diagnose a clunk.
Long story how we got there, my grey beard, Indy mechanic suggested going to the dealer as my issues pointed to a possible ABS system failure, and he thought it may be covered by MB's 25-year extended warranty for ABS modules but needed to dealer to diagnosis for warranty purposes. The W210 has a 38-pin diagnosis port as well as the OBD-II. All relevant info comes from the 38-pin port. I have a Foxwell NT-510 that is up to the task, but it pointed to several areas. Net/net the warranty extension was only for W211's, grey beard has now determined I have a bad steering wheel sensor which is NLA. He is willing to roll the bones and have me get a used one off Ebay and he'll install it.Crazy. Wonder if that’s because of obsolete computers for diagnosis, or what. Most work doesn’t change between a 50yo car and a modern one.
Back in the early 2000s, I took some diesels to the then-local dealer, and they had the foreman work on it because he had the most expertise. But that was relative to the engine work. Nothing on the suspension or other parts was unique.
I believe that video was staged to exaggerate the excessive play and noise. That inner CV triplex joint is missing all three of the roller bearings which take up the slack (see photo below which shows the bearings which aren't in the video).That second video is wild! That's a ton of play. Smart of him to illustrate with boot removed.
Take a good look at the front control arms, both upper and lower, as well as ball joints. Check subframe bushings.
If the car was old enough to need shocks and struts, there is a good chance that the control arm bushings are worn out as well.
