- Joined
- Sep 28, 2002
- Messages
- 39,793
Hockey (Okay, if said with a heavy foreign accent)
Not too long ago some of the board members stated that they added "anti-foam" to regular AFT to make it suitable for the Chrysler/Mopar 7176 spec. This challenged my source on the matter, which was a trans rebuilder. The rebuilder used bulk AFT and added what he called "friction modifier" to the fluid. This made sense. Also one non-company sponsored Mopar site dealing with their automatics stated that if the wrong fluid was used .."micro-grabs" would occur in the close tollerance overdrives. Converter clutch chatter was also mentioned as a side effect. Neither of these sources mentioned 'ant-foam" or "foamation' as a cause or remedy.
Neither have any sites that I've visited including Redline's (site sponsor). The ATF C+ mentions "modified friction" including this one Chrysler 7176 and several varieties of Chrysler ATF-Plus. All are "friction-modified" lubricants
Now the two members (I forget who) ..referred to "anti-foam" as though it was the most common of knowledge and nomenclature in the industry.
Yet I have yet to see ONE referrence to it in an authoritative source.
Can someone say "Oh ..yeah, the MOPAR stuff in the bottle IS a friciton modifier AND antifoam".
or ...
"...Everyone knows that this is an anti-foaming agent that is also a fricition modifier.
Reason? I have a decent stock of Mobil 1 ATF. At the time (and as far as I know now) they did not have 7176 fluid available in the synthetic. I want to use this fluid to change over my 30RH (904/909/999) in my Jeep and want to know REALLY what the story is.
Ahhh ...the thread Do you see my cofusion?
or ...
